simple questions
Old Jun 30, 2009 | 06:48 PM
cobra12's Avatar
simple questions
The bimbo who serviced my z28 last overfilled the tranny with fluid. What would the possible side effects be?
What should I do about it?
My tranny is leaking. The front two bolts don't tighten. They just turn over and over. Is that a problem?
Old Jun 30, 2009 | 09:33 PM
n2ceptor's Avatar
The bolts holding the pan??? If so, then you will probably have to get a heli-coil kit to fix.. As for the over filled, yes it is a problem..... You can buy a hand suction pump for 2~3 dollars and remove the excess through the filler tube....
Old Jul 1, 2009 | 07:40 AM
rngilliland's Avatar
Are you checking the fluid with the engine running? If you check it without the engine running it will look like it is overfilled.
Old Jul 1, 2009 | 09:21 AM
cobra12's Avatar
i did not know that. i'll check later today. (i feel stupid)
Victor Lamb
Aug 26, 2017 02:52 PM
Hurin
Dec 13, 2014 07:38 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Geoff Chadwick
Jul 31, 2002 12:07 PM
