79Z need to put it in DD mode temporarily
Old Jun 29, 2009 | 11:44 PM
SupplySgt.'s Avatar
well making the 79 into a toy is going to have to be put on hold. due to the non starting issues in my IROC and the tranny losing 5th gear in my 96 Camaro i need to put my 79 into daily driver mode. really all i need is a new tranny. I'm thinking 700R4 for the time being so i have that overdrive gear since my commute is largely interstate. current tranny is TH350 but it's blown. I'm almost finished rebuilding the carb for the 350 that's in there just time to go tranny hunting. Anyway my question is will the 700R4 be fine for it or would anyone recommend something different? As far as I can tell it will be fine for it just wanting some second opinions. Thanks in advance
Drew
Old Jun 30, 2009 | 05:24 PM
angel71rs's Avatar
Th700 will work, but if I ever lunch the th350 in my 71, I'll go with the th200. Reasons here: http://www.chevyhiperformance.com/te...wap/index.html
One thing to be very careful with is the TV cable adjustment on either the 200 or the 700. Research carefully. TV cable has control over shift points and tranny pressures. Bad adjustment = low pressure for throttle opening = burned up tranny.
I've seen guys burn up trannys when they chose to mickey mouse the carb bracket instead of buying the proper aftermarket bracket for their carb, resulting in bad adjustment/low tranny pressure/$$$ for a rebuild/having to buy a proper bracket anyway.
Old Jun 30, 2009 | 05:39 PM
SupplySgt.'s Avatar
yeah i was doing some additional research last night after posting this and saw about the 200R4. And I did see about adjusting the TV cable properly. 3/16th can make a huge difference from what i could see. Thanks for the help though i appreciate it.
Heathen1
Jan 2, 2016 04:27 PM
WildRidez
Feb 23, 2015 07:24 PM
Jan 23, 2015 01:13 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
NewsBot
Dec 28, 2014 06:20 PM
