Wet kit LT1 guys inside...
Old Jan 15, 2003 | 10:34 PM
Dave 96TA's Avatar
Wet kit LT1 guys inside...simple Q
Need to know (pics would be awesome) how your fuel solenoid ties into your fuel system...
See, I bought what was supposed to be an NX #20920 (LT1) kit but it turns out the half with the fuel 'T' and solenoid parts is #20923 (EFI Import kit) so I'm wondering if this 'T' fitting is the right part to use or if the 20920 comes with another fitting specific to our fuel systems. All the other parts seem to be identical between the 20920 and the 20923 (except the jets [35, 50, 75hp]).
Thanks!!
Old Jan 16, 2003 | 02:36 AM
VINCELEE123's Avatar
ties in
i belive its on the back of the fuel rail
Old Jan 16, 2003 | 06:16 AM
RacinLT1's Avatar
i dont have any pictures but my fuel line is hooked up to the the test port on the fuel rail. it is bhind the intake,pop the schreader valve out,and screw the line on.
Old Jan 16, 2003 | 09:15 AM
justahoe's Avatar
I think it is just a 4an fitting that fits on the schrader valve, at the back of the intake. Should be able to get a line w/ the 4an pretty cheap.
Old Jan 16, 2003 | 11:48 AM
Dave 96TA's Avatar
hey guys thanks for the replies but...
i know you tap into the test port on the rear-right of the fuel rail, but is yours a 'T' shape with a 04-an threaded section and then split into two 3/8" (looks like) barbed slip-fits? ok i found some pics to help illustrate
http://www.in-design.com/~gatorman/juice/20923-t-1.jpg
http://www.in-design.com/~gatorman/juice/20923-t-2.jpg
thats the 'T' i have with the 20923 kit...the rest of the stuff looks the same. question is will that work on the LT1? if not what do i need, a 04-an/04-an male/male connector? thanks!
Old Jan 16, 2003 | 12:07 PM
Derrick Redd's Avatar
Mine is screwed directly to the fuel rail. No barbed slip-fits. You should be able to just screw the fuel line into the fitting on the rail.
Edit....What Loadre said.
Old Jan 16, 2003 | 12:11 PM
Dave 96TA's Avatar
ok so this wont work, i'm gonna call NX and see what they can do for me
thanks fellas
Old Jan 16, 2003 | 12:55 PM
Loadre's Avatar
I don't think you got what Derrick said, the fuel line should just screw on to the fuel rail, no fitting needed.
Old Jan 16, 2003 | 02:38 PM
KTamez's Avatar
As stated before, just don't use the T at all. Remove the schraeder valve using a tire valve core removal tool, and just put the line (The red fitting) directly on the schraeder valve and you're done.
Kurtis
Old Jan 16, 2003 | 03:09 PM
Dave 96TA's Avatar
sweet! no wonder I couldnt see any sort of fuel rail fitting for the LT1 in the 20920 pics...good news
Old Jan 17, 2003 | 04:11 PM
11sec's Avatar
Dave spray that thing and so I have a bolt on lt1 spray guy to run.
alphaauto
Jan 23, 2015 07:42 AM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
ezcheeze15
Aug 26, 2002 01:28 PM
ezcheeze15
Aug 8, 2002 12:27 AM
Red97LT1
Aug 7, 2002 05:45 PM
