V8 Tank on V6?
Old Jun 23, 2009 | 04:29 PM
Raleigh TA's Avatar
Former Vendor
V8 Tank on V6?
How simple is it to swap a tank and fuel pump from an LS1 Camaro to a 99 V-6 Camaro?
Old Jun 24, 2009 | 12:24 AM
SupplySgt.'s Avatar
well if you consider dropping a fuel tank to be simple....I don't know how it is on camaros cause i've never have to do that but i know on my old truck it was hard as hell to get the tank off
Old Jul 8, 2009 | 09:42 AM
Need4Camaro's Avatar
It's not simple. To drop the tank, you need to drop the rear axel and suspension. The pump can be swapped via the back door method if thats all you're trying to do. Why do you need to swap the tank?
Also btw, just incase you didn't realise, the fuel pump on the LS1 is DIFFERENT than the one on the V6. The LS1 pumps alot more fuel so unless you're running some serious internal mods, you will wind up running rich...
Old Nov 19, 2009 | 11:22 PM
baalic's Avatar
Is the tank not the same on the v6?? I know its the same size and just assumed it was the same...
On 4th gens anyways..
KYWes
Sep 26, 2015 08:49 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
Pwilson59
Sep 3, 2015 08:47 PM
350350
14
Aug 11, 2015 12:03 PM
Alibi
Aug 1, 2015 07:50 PM
