Clutch issue, please help
Old Jun 23, 2009 | 03:40 PM
blynn's toy's Avatar
I bought a 94 3.4 that the misses wanted it was really cheap and needed the head gasket replaced. Long end of short I replaced the motor and pulled the trans to bolt up and put in together, before I pulled the clutch was fine, now when its been running for a while it acts like the clutch doesn't wanna dis engage, there is no way of bleeding the clutch, but that is what it is acting like, don't know where to start to fix issue, that and and uneven idle from 600 to 1100 rpms with a slight miss to it, let me know am new with the 6 cyl camaro and need help, thanks in advance steve
Old Jun 24, 2009 | 12:31 AM
SupplySgt.'s Avatar
Make sure it has enough fluid. sounds like there's not enough fluid in there. Also make sure the slave cylinder and master cylinders aren't leaking.. And as far as the misses it's just like any other engine. Check your plugs (which is easy on the 3.4 to get to don't tell me it's not) wires and coils. Also check make sure your timing is correct and then check the EGR valve and O2 sensors. make sure the intake gasket isn't broken as well. that can cause a bad idle. and if it has over 130k I would at least check the motor mounts. Those can make it seem like a rough idle. My first Camaro was a 3.4 that wasn't in the best of shape but i figured things out eventually
timmy39120
May 8, 2015 11:41 AM
blkWidow
Apr 21, 2015 01:56 PM
BigWil
Mar 29, 2015 12:24 PM
HectorM52
Jan 30, 2015 11:08 PM
Cartercarterr10
Advanced Tech
Jan 15, 2015 09:13 PM
