Stainless Steel Brake lines 4?
I saw a set of stainless steel brake lines, but it is only saying that the kit has 4. My car is a 95 T/A M6 without traction control. It should have 5 lines. I am guessing that this kit does not include the line that goes across the rear, it just has the lines for each wheel. Would it be a bad idea to get this kit, or would 4 lines work just as well as the 5 line kit? Any help would be great.
Thanks,
Travis
Thanks,
Travis
If you are going to do it you should do it correctly and do all 5 hoses. Here is a link to some DOT SS hoses for you.
http://www.hotpart.com/shop/index.ph...ct_detail&p=38
Can you buy just the 2 rear center lines? I bought a more expensive Summit kit that sent the wrong type for the rear center section, for a non traction control car. I wish I would have known about your kit before hand.
