how do you disconnect...
Old Jun 20, 2009 | 10:24 PM
cobra12's Avatar
...this hose
Old Jun 20, 2009 | 10:28 PM
n2ceptor's Avatar
You cant..... Its crimped on.... The hose comes as an assembly.....
Old Jun 20, 2009 | 10:31 PM
cobra12's Avatar
I need to take it and make it look like this....
Old Jun 21, 2009 | 07:40 AM
TrybalRage's Avatar
If you are willing to trash the hose just to get that middle section you can get a dremel and cut the crimped part, then bend/twist/yank it off. I did that with an old car and then bought new hose and clamps to go on either side.
Old Jun 21, 2009 | 09:23 AM
cobra12's Avatar
Thanks. I was originally going to use my dremel, but it doesn't work. I think it needs brushes. I was able to get it off using tin-snips and pliers.
Old Jun 21, 2009 | 03:28 PM
Sure you can. You slice a groove (Dremel with cutoff wheel works well) into the swaged collar (being careful not to cut into the pipe inside) and then peel it off. Hoses are available individually for this purpose. Secure the new hose with a normal clamp.
Old Jun 21, 2009 | 05:35 PM
cobra12's Avatar
That would've worked better. I just need to get dremel brushes.
