91 Z28 runs great for 10 mins. then dies
Old Jun 19, 2009 | 09:27 PM
artstutts's Avatar
Angry 91 Z28 runs great for 10 mins. then dies
Why would my '91's TPI 5.7 ltr run great for 10 minutes after a cold start but then start to idle rough and try to die when I give it throttle? It starts to knock also. Ive replaced the ECM and the O2 sensor. It does not throw any codes so Im shooting in the dark. My next guess is to replace the EGR valve but Im tired of just spending money on parts that arent bad. Can anyone help?
Old Nov 6, 2011 | 10:06 AM
vette1954's Avatar
Re: 91 Z28 runs great for 10 mins. then dies
I have this problem as well with a 91 z28 with a 305 with TPI. It will run until it comes up to operating temp and then dies and will not star until it cools down. Did you find your problem? I am going to continue to look versus replacing parts.
Old Nov 6, 2011 | 11:22 AM
jproz1167's Avatar
hook up a vacuum gauge and fuel pressure gauge. if no codes present then you have a problem the ecm can not see. Like a dying fuel pump, plugged cat, egr solenoid causing egr to open and killing motor, bad multec injector shorting and the injector drivers shutting down.
bfmv13trivium
Jan 14, 2015 09:57 AM
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
nophix
Nov 30, 2014 10:26 PM
Lederman1976
Nov 30, 2014 05:21 AM
