anyone with centerline telstars in here please
Old Jan 15, 2003 | 10:22 AM
mywhitez's Avatar
i called centerline today and the tech said they wont fit because the brakes hang up in the back. anyone running the telstars? id like to know did you use a spacer? will they even work?
thanks
jay
Old Jan 15, 2003 | 11:12 AM
kazman's Avatar
I have a set on the front 135401547 4X15. I had to remove the disk brake pad retaining clip. I just snaped it off. No big deal. I am using the cheapest pep boys brake pads so other's may fit as is.
These wheels just fit. No spacers or grinding required.
I just ordered 8X15's 135806547 and Et Street 26x10.5-15 for the rear. These are the same wheels and tires that gm high tech used for their camaro. I think they will just fit too.
Old Jan 15, 2003 | 11:20 AM
sseeya's Avatar
What's holding your brake pad in place now?
Old Jan 15, 2003 | 11:28 AM
kazman's Avatar
The calibler. The clip really doesn't do much. I think it just holds the pad in place as you put calibler over the rotor. The clip is on the outside pad only.
Old Jan 15, 2003 | 09:35 PM
mywhitez's Avatar
anyone else?
Old Jan 16, 2003 | 01:31 AM
OutKast's Avatar
Perfect fit for me....pics too!!
Check them out. Absolutely zero changes were made to put them on my car.
http://bedford.no-ip.org/Centerline_Telstars.htm
need to take new pics as the rear was sitting high in those, I was tring out the V6 springs in hopes of better 60ft times to no avail.
Old Jun 22, 2003 | 10:39 PM
Twice The Fun's Avatar
this may be old, but i am interested in Telstars...OutKast, what size are the nittos out back??? wondering how much of a 26x11.5x15 ET Street will poke out from the quarter panel.
Old Jun 23, 2003 | 01:11 PM
OutKast's Avatar
I want to say that they are 275/50?/15. I'll double check when I get home. I have found that with standard z28 rear coil springs they will hit the lip of the fender a little. Easily solved by throwing in the V6 springs which give me a better launch anyway.
Check this link for a few pics of them on with the V6 springs.
Fastbird93
Apr 9, 2016 07:01 PM
RUENUF
Mar 13, 2016 03:37 PM
kazman
Middle Atlantic
9
Jan 30, 2003 03:47 AM
Kain
Dec 31, 2002 05:34 PM
JMiller99
Dec 30, 2002 12:54 PM
