VATS enigma
Old Jun 15, 2009 | 01:12 PM
Diamhea's Avatar
VATS enigma
Well here I sit again, stranded for the umpteenth time by my security light. I've battled this thing for over 2 years now, and after endless reading on resistors, lock cylinders, etc. have finally considered my case to be unique.
After the issue first began popping up I reverted to using my remote start (Which was on the car when I acquired) to fire the car up, every time. However, for some reason on randomly and especially on unusually hot days (like today) the prevalence of the security light is heightened. I pulled the cover off under the steering wheel to tackle it last summer and stood in awe as the white/purple wired resistor plug fell into my hands. It was already cut out /w a resistor built in! (I'm assuming this is required for remote start on VATS vehicles, right?).
But if I have a resistor wired in for the remote start, why would I still get a security light at all? Especially when I'm remote starting (not even touching the ignition other than turning the key into "on" every time I start) Is there some way that the ohm rating in the resistor somehow fluctuates with outside temperature, humidity, etc. and makes it not match the reading to start sporadically? Worth noting is the fact that when security comes on, it usually takes several tries, its never one-and-done. In fact I've had to get the car towed before because of this.
Car is a '94.
Old Jun 15, 2009 | 01:26 PM
JeremyNYR's Avatar
how well is the resistor spliced into the wires? Did they do a good soldering job, or did they use butt connectors? If all else fails, you can disable VATS in the PCM.
Old Jun 15, 2009 | 01:30 PM
Diamhea's Avatar
To be honest, I have no idea. I looked under there and it was a whole mess of crap from what I understand is the remote start. I might have to take another stab at it if all else fails..
Old Jun 15, 2009 | 01:50 PM
JeremyNYR's Avatar
I'd look at the quality of the electrical connections if your problem is intermittant. You might have all kinds of ****ty connectors and half-assed splices that give you inconsistant performance.
Old Jun 15, 2009 | 02:38 PM
ACE1252's Avatar
What is the resistance of the pellet in your key and the resistance of the resistor wired into the VATS system?
Old Jun 15, 2009 | 06:47 PM
MikeGyver's Avatar
lol, just have the VATS disabled in the tune already... DONE
Old Jun 15, 2009 | 10:42 PM
Nothing really unique at all. Resistance increases with heat, especially if you have a marginal connection where the resistor bypass needed for remote start was added in. Just fix your bad connections.
Jeff1904
Jun 5, 2016 05:00 PM
walt355
Mar 16, 2016 09:35 AM
colts0455
Oct 4, 2015 09:47 PM
colts0455
Sep 27, 2015 01:07 PM
