Poping in rear end?
Old Jun 10, 2009 | 05:14 PM
LT1 POWR's Avatar
Poping in rear end?
I don't know if this should be in suspension/chassis or drivetrain forum as I don't know exactly what it is yet. But there is a pop/bang coming from the rear end after I drive over select bumps in the road. Usually after sharp drop offs. The only change I made to the rear of the car recently was the Strange 12 bolt. Other than that I can't think of anything else it could be.
The car has a full suspension, UMI road race k-member, chassis mounted torque arm with DS loop, adj. panhard bar, adj. LCA's and relocation brackets, Strano 35mm front and 22mm rear sway bars, Koni SA shocks and Strano 1 1/4" lowering springs. Its got QA1 rod ends all the way around, but I've never heard this "pop" until after I installed the rear end.
Along with the rear end install was a new chrome moly 3" drive shaft, built 4L60E tranny, Vigilante 2800 3 disc stall, UMI road race K-member, Griffin radiator, Meziere HD electric water pump and I deleted the AC and added stainless braided brake line ends. I also rolled my fenders so they's stop cutting up my tires.
Anyone have any suggestions.
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
