PCMFROLESS tuning help!
Old Jan 14, 2003 | 04:55 PM
1loudz's Avatar
I got my new upgrade for my new cam from Bryan, but i cant it it work right! When i run flshprog it goes through everything as normal, ie: select bin file..... select port #........ then it tries to connect with the PCM, it ries for a sec then it aborts and says security violation (0) at the bottom of the screen.
Anybody with PCMFORLESS tuning have any idea whats going on?
I need to get this thing tuned pretty quick!
Thanks,
Ryan
Old Jan 14, 2003 | 05:36 PM
1994TransAm's Avatar
email bryan,
he will know!!!!
Old Jan 14, 2003 | 05:39 PM
mtxpert's Avatar
You're not waiting long enough after you turn the key on. Wait 20 seconds or so after you turn the ignition key on and then hit (P)roceed.
Mike
Old Jan 14, 2003 | 06:31 PM
1loudz's Avatar
MTXpert! thank you very much! thats exactly what was wrong!
It worked great now.
Thanks again,
Ryan
-oh yeah, the reason i asked here was because Bryan has yet to email me back, and i wont have my dad's laptop after tonight.
Old Apr 2, 2003 | 11:31 PM
1QUIKTA's Avatar
Need help ASAP-we did the wait 20 second thing and the car now is flashing the SES light and will not run. What to do????? The program took 100% and it said completed.
Old Apr 2, 2003 | 11:35 PM
turbo_Z's Avatar
sounds like you fried it.
pull the battery cable or pcm fuse and see if that fixes it. but if the SES still flashes and your fans come on then your PCM is toasted.
Old Apr 2, 2003 | 11:38 PM
1QUIKTA's Avatar
How in the heck did it fry? It said everything was fine, completed, ECT. This is not a good night. Finally got my car together after a month and racing is tomorrow. My PCM fried b/c the program we downloaded was in EML (not bin) form. Then my buddy loaned me his and this happens
Old Apr 2, 2003 | 11:45 PM
turbo_Z's Avatar
eh?
if you were using the file bryan sent you then i am sure it was a .bin file. how did you convert the file? there are only 2 that i know of... the .bin and .lt1 used on OBD2 cars.
Old Apr 3, 2003 | 12:47 AM
1QUIKTA's Avatar
Thats just it-we never converted it to EML. It just downloaded that way and it was overlooked. As far as the second PCM-who knows what happened to it.
Old Apr 3, 2003 | 12:51 AM
turbo_Z's Avatar
ok i dont quite understand...
you got a mail order tune from Bryan and couldnt get it to upload because of security codes. then you figured that part out and got it to accept a flash and all was ok? but now you just tried again and as it looks fried the computer. what is this 2nd PCM? and did you flash the computer 1 or 2 times?
Old Apr 3, 2003 | 01:00 AM
1QUIKTA's Avatar
I don't quite know what happened either. I posted in the computer section. Maybe this explanation may be better.
http://web.camaross.com/forums/showt...hreadid=102363
Each one was only flashed (is that the programming part?) once. My friend knows about this not me. The first PCM was just a stupid mistake in the computer.
Old Apr 3, 2003 | 02:41 AM
97 WS6 T/A Conv's Avatar
Copy/Paste from other thread,
I find it strange that Flash Program could locate a EML file. Seems like it needs to be a bin file to even be on the DOS menu. Did the EML have a ".bin" extension? I know none of this helps your issue I'm just curious. I would have guessed you didn't turn the key off after upload but you stated the fans never turned off and the SES light was flashing so now I don't have a clue as to what happened in your case. This is the first I have heard of this problem.
How is the condition of your car battery? Were you running an electric waterpump while the PCM was uploading (pulling more draw from the battery) Did you use an A/C source for your laptop or did you run that off of the car battery too? Seems like none of that would matter if the program indicated 100% complete but something to consider for next time.
I will tell you that when you get your PCM replaced make sure you get the PCM with a socket installed that way if you fry your pcm again all you have to do is replace the chip and try again, no more shipping back and forth. If you get it through Bryan have him program the PCM while he has it.
Aug 24, 2015 06:41 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
Shookiez28
Jul 23, 2015 01:55 PM
