oil leak from hell
Old Jun 1, 2009 | 05:26 PM
lt1cruzin's Avatar
oil leak from hell
I have oil dripping off of starter,off of converter cover, and off of oil filter.Oil cooler is gone ,and im assuming its my intake leaking, but it doesnt seam wet.The whole underbody of my car is covered in oil.Its so bad, I can see a line of oil everytime leave the driveway.I go through a quart every few days, and i know its not burning it.What could be leaking that bad? I have wiped down everything, and it looks like its comming from both sides of the motor.After just a block or so,you can see oil comming off of the top of the starter and top of converter cover.
Old Jun 1, 2009 | 06:17 PM
moparman's Avatar
Stick your hand behind the intake and see if you get an oil covered hand.
Old Jun 1, 2009 | 06:23 PM
lt1cruzin's Avatar
Not really.Its kind of dried oil, like its been fixed befor.But im going to take a closer look and also take picks tomorrow.
Old Jun 2, 2009 | 01:06 PM
lt1cruzin's Avatar
Its really not that wet back there.But i can see that oil is dripping on starter real bad.The only thing i can think of is dipsticlk or intake.The tranny,everything is coverd in oil even after cleaning it and mabey 10 miles.
Old Jun 2, 2009 | 03:39 PM
Angelis83LT's Avatar
Similar oil leak a while back. had oil all over the bottom of the car, on the cover, oil filter, starter. Found it pretty quick though, it was the oil pan gasket in the front behind the Harmonic Balancer.
Old Jun 2, 2009 | 06:32 PM
lt1cruzin's Avatar
It might be but it looks like old oil by there.I had a opti and water pump seal leak, but fixed that already.Can a big backfire blow out the intake gasket?when i was replacing the opti, I had a plug wire crossed and it back fired through the intake and throttlebody.
Old Jun 4, 2009 | 12:52 PM
lt1cruzin's Avatar
Well im doing the intake this weekend.Im getting smoke comming through the tranny tunnel now.Ill let ya know how it goes.
Old Jun 21, 2009 | 06:27 PM
lt1cruzin's Avatar
It was the intake leaking.Changed the gasket last weekend, and a huge chunk of rtv was missing on the rear passenger side.I think it blew out when it backfired on me after I put the opti on and had a few wires crossed.
Magenta_Hearts
Mar 29, 2017 08:54 PM
surreybrad
Apr 22, 2015 06:40 AM
BigWil
Mar 29, 2015 12:24 PM
artic94
Jan 17, 2015 11:19 AM
