Changed Fuel Injectors no start
Old May 30, 2009 | 09:57 PM
awdfun's Avatar
Upgraded my fuel injectors from 42lb to 72lb due to a little extra boost. I changed the injector constant in tunercat but the car will not start. Is there any other item i need to change. Need to get the car started so i can start tuning.
Old May 30, 2009 | 10:23 PM
MikeGyver's Avatar
Are the new injectors of a lower impedance? If so are you using a driver for them?
Old May 31, 2009 | 07:46 AM
awdfun's Avatar
No they are still high impedance.
Old May 31, 2009 | 11:19 AM
Did you check to see if you blew a fuse? Check for +12V on the pink wire to each injector.
Old May 31, 2009 | 01:07 PM
awdfun's Avatar
Checked it with noid tester and voltmeter. Spark plugs are wet. Checked ignition also and has spark. I am waiting for my new ee file from tunercat. My ee file does not have minimum injector pulse width on it (older ver).
Old May 31, 2009 | 09:43 PM
MikeGyver's Avatar
is the 72lb rating @ 43.5psi?
Old Jun 1, 2009 | 03:10 PM
awdfun's Avatar
yes
Old Jun 1, 2009 | 06:29 PM
awdfun's Avatar
Found problem. Broken cam pin..
Old Jun 1, 2009 | 08:51 PM
MikeGyver's Avatar
How'd that happen?
Old Jun 2, 2009 | 03:10 PM
awdfun's Avatar
Dont know. Called compcams and they have not seen it. only has maybe 200 miles on it.
AdsoYo
May 2, 2018 03:21 AM
Alex Barnes
Jan 24, 2015 10:21 PM
birdblack
Dec 30, 2014 06:59 PM
Jul 4, 2005 05:00 PM
