How do I know if my front wheel bearing are going bad?
Old May 28, 2009 | 09:43 AM
km9v's Avatar
How do I know if my front wheel bearing are going bad? Is there a particular noise I should hear? I am hearing a slight "wobble" sound coming from the front. Is there a grinding feel or clicking when they are bad?
Old Jun 2, 2009 | 09:04 PM
NED4SPD's Avatar
You will hear a grinding noise when wheel bearing are going, it will be a constant noise but the pitch will change when you turn the wheel right to left when driving. Now there are exceptions to everything I have had bearings make no noise and be ready to fall out in my hands. Raise the suspension properly and check to see if it is loose. If you have a wobble you might have other suspension issues like tie rod ends etc.
Old Jun 7, 2009 | 01:27 AM
MTL_Z28's Avatar
I actuallly just had my front driver side wheel bearing replaced as there was some slack in it... I was getting an intense vibration in my steering wheel at highway speeds. Don't know if that helps you.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
dpw21562
Jan 23, 2015 04:58 PM
Dec 4, 2014 11:56 AM
