Nitrous Advice
Old Jan 14, 2003 | 07:19 AM
DAC350's Avatar
Nitrous Advice
With my setup, would I be safe with a 50 or 75 shot? All stock internals. Thanks.
Old Jan 14, 2003 | 01:43 PM
Fuels94TA's Avatar
It's can be done with a low shot but since in your sig. it shows that your supercharged. Your going to need to tune/progam your combo to work together. I've heard this combo can cause problem's if you don't know what your doing. I belive that stock bottom end can hold ablout 450-500 h.p.
Vinny
Old Jan 20, 2003 | 06:12 PM
djlup's Avatar
I think that you could be safe with a 50 to 100 shot as long as it's a wet kit.
I would start off with bigger than normal fuel jets.
Old Jan 20, 2003 | 09:55 PM
94DROPTOPZ28's Avatar
I would be VERY careful with this!
I made a post about this a few months back maybe you can do a search on it, but I was told by some people here that have a lot more experience with Nitrous than I do NOT to do this. Unless you change your set-up to better pistons & rods.
Old Jan 20, 2003 | 11:37 PM
XKnightRider's Avatar
Re: Nitrous Advice
Most guys that I know using a blower and N20 have fordged internals. If you do this, just make sure you leave yourself enough money to be able to buy new pistons. That is going to be the weak link! Hypertetic pistons won't like all that extra hit for long.
The next weak link will be the rear end....cuz I think your going to need slicks to hold all that power, and GM rears don't like slicks
David Dempsey
Mar 12, 2016 12:42 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
95blkss
Sep 22, 2015 03:18 PM
