Radio auto antenna lead?
Old Aug 1, 2002 | 10:08 PM
$hawn's Avatar
Post Radio auto antenna lead?
I had my stereo stolen and they took the wire harness, the only wire I didnt really know what was for, was some wire that ran back to my amp and it's for the radio auto antenna lead, and i'm not sure what wire on the harness it was crimped to, anyone know. Thanks
93 Z28 Patriot Red A4
Old Aug 1, 2002 | 10:22 PM
megabass's Avatar
Post
Check the light blue wire with the white stripe. You can hook a multi-tester to it as an easy test.
Old Aug 1, 2002 | 10:58 PM
$hawn's Avatar
Post
Saturday morning i'm going to get a new stereo and wire harness, ill check it out when I get everything hooked up, What does it really do anyways, is it important to have it hooked up, will it still work if its' not hooked up? Thanks
Old Aug 2, 2002 | 11:19 PM
$hawn's Avatar
Post
Anyone know if it's important or not. Thank you
Old Aug 3, 2002 | 04:59 AM
LS1 RULZ's Avatar
Post
The lead is used to power up your amps and power antenna when you turn on the system. So, yes, you need to have it connected. At least to your amplifiers. Since Camaros don't have power antennas you don't need to worry about that.
PROJECT X
Apr 17, 2015 12:13 AM
ChrisFrez
Feb 15, 2015 08:12 AM
ChrisFrez
Jan 11, 2015 03:47 PM
Red97LT1
Aug 3, 2002 07:29 PM
