wideband output to ac pressure port?
Old May 8, 2009 | 08:13 AM
lt170chevelle's Avatar
Ok i have seeb some people mention hokking up the wideband analog"i believe" output to the ac pressure port so that wideband readings will show up on logging.But is there anything else needed or do i simply hook it up to it? I tried searching for this and didnt find anything. is this the only way to hook it up to something to read wideband info on a datalog?
Old May 8, 2009 | 08:54 AM
jay_rich's Avatar
I think the only difference is it will read as PSi or Volts or something like that.
If u go on the AEM site (if that what u have) it will give u a conversion chart for Volts to AFR
Jay
Old May 8, 2009 | 09:31 AM
bobdec's Avatar
Here is the sticky.. https://www.camaroz28.com/forums/arc.../t-535603.html . Basically you need a Wideband & Control unit that puts out 0 to +5V, then a switch on the a/c pressure switch that sends either the wideband or a/c pressure to the PCM, then you have to set up the Datamaster 'custom data feature' display the 0-5V as AFR.
Old May 8, 2009 | 09:48 AM
DOOM Master's Avatar
What he said. The writeup is excellent and should get you exactly what you need for running a wideband through Datamaster.
Old May 8, 2009 | 12:02 PM
WS6T3RROR's Avatar
Except it does not always match exactly... Sometimes it can be off as bad as 0.3 A/F. Your mileage may vary, but I worked quite a bit to make the datalogs read similar to the afr displayed on the wideband gauge. So take the readings with a grain of salt, it works but it is not perfect. Adjust the y intercept to improve the accuracy in the 12.5-13 range as best you can, dont worry about areas that are non wot if you run closed loop. They are not that critical.
Old May 8, 2009 | 12:48 PM
ok well this is an open loop 2bar setup and just needed to to know what my afr is looking like the whole run thanks.
Old May 18, 2009 | 11:43 AM
ok well i got the wiring done but how the heck do i adjust the values and what not on the datamaser program to do the conversion? I am not a programming wiz when it comes to real computer programming.anybody give me some insight on this part of the process?
Old May 30, 2009 | 08:59 PM
95TALT1's Avatar
Im not trying to thread jack but can you use the FAST wideband o2 on the datamaster? I have the dual widebands.
Thanks,
Waylon
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
lildemars09
May 28, 2015 07:54 PM
Roadie
Feb 16, 2015 10:34 AM
IDOXLR8
Aug 6, 2002 12:30 PM
