Bent Tie Rod??
Old May 6, 2009 | 10:22 AM
4thgencamarofan's Avatar
Bent Tie Rod??
Is it possible to bend a tie rod from a car being pulled out of a ditch. The top of the front driver side tire points outward away from the car. Any other parts that might be borken.
Old May 9, 2009 | 03:28 PM
95TA04GOAT's Avatar
Inexperienced or lazy tow truck operators could easily bend a tie rod by hooking to it to pull a vehicle. But the most obvious cause of the bent part is likely falling into the ditch in the first place. If you say the top of the tire is out (positive camber) then it's probably not a bent tie-rod but more likely a bent lower control arm.
Old May 9, 2009 | 11:15 PM
Either way, it's going to need a good going over.
Old May 11, 2009 | 10:09 PM
Ok thanks i'll let my friend know. When he pulled the car out of the ditch he pulled it out by the tires. Just wondering if that is the proper way to pull a car out of a ditch.
Old May 11, 2009 | 11:31 PM
chevyz4life's Avatar
No!
Old May 12, 2009 | 06:03 PM
I wasn't thinking so.....that rotten SOB "tow truck guy".........now that's more money out of his pocket.
football4life
Oct 4, 2015 07:48 AM
CARiD
Sep 30, 2015 05:44 AM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
