dual purge conversion???
Old Jan 12, 2003 | 11:31 PM
Hawk's Avatar
I have the nx kit, with the regular purge solenoid. i ran a stainless line, single purge. On the nx website, they have this part number 15602 which says dual purge plumbing kit. I searched the net, couldn't find out what it actually includes, or pictures of it. Can anyone help me out by telling me what that kit has, if it will work with my purge solenoid, and how long the lines are. Thanks alot.
Old Jan 13, 2003 | 09:36 AM
RacinLT1's Avatar
I built my own dual purge with some brass tubing and -3an/1/8" pipe thread T block.
Old Jan 13, 2003 | 02:47 PM
Its just a matter of getting some 1/8" copper tubing, and using some 1/8" compression fittings - mainly a "tee" as Dirk mentioned above - to split you current single discharge line into two lines. Try and keep the tubing AFTER the tee as symetrical as possible if you are concerned about how it looks...... I just dump the purge inside the front fender well.... no "visual" effects, only "audio"..... . Keep 'em guessing.
Old Jan 13, 2003 | 04:27 PM
LT1Thunder's Avatar
Definately do not waste your money on a kit. You can just modify it yourself to look like a dual purge with one solenoid. There are a lot of peoples cars that I have seen pictures of that did it without any type of kit. You just have to go to the hardware store and use your imagination! I plan on doing the same thing if I ever get a chance to do my install on my kit. Btw, I like the way you have your bottle mounted, I just don't have the money to get a bottle opener so I might just mount it in the back seat for easy access!
-Rick
Old Jan 13, 2003 | 07:34 PM
Loadre's Avatar
I used stainless hose (like the fuel line and N20 hoses) from the purge solenoid and ran it to a 'T' and ran two more stainless hoses from that. All the parts were N.O.S. I think. Pics are in sig if cardomain is up.
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
RX Speed Works
Oct 1, 2015 10:19 PM
tdigger9899
Sep 7, 2015 10:56 AM
