HELP!! Having trouble on amp install
Old Jul 28, 2002 | 07:09 PM
Snake Slayer's Avatar
Unhappy HELP!! Having trouble on amp install
OK, my car is a 00 ss, I installed an aftermarket headunit a couple of days ago, today I,ve been trying to install my amp and an MTX thunderform, all the wires are ran the amp has power, I even tried a different set of RCAs but still nothing. I don't need the PAC with an aftermarket head unit do I? Should my remote wire be hooked to the head unit I'm using or the adapter harness? Sorry so long I'm just pulling my hair out trying to figure this out. Thanks for any help.
Old Jul 28, 2002 | 07:32 PM
LS1 RULZ's Avatar
Post
NO
Run the remote lead directly from the HU to the amp.
Old Jul 28, 2002 | 08:33 PM
Post
Thanks LS1 Rulz. Well, I've got the remote hooked to the head unit but still no sound. I tried using another amp but the power light on it just blinked, no sound. Anybody else have any suggestions, I really don't want to take this thing to a stereo shop but it's starting to look that way
Old Jul 28, 2002 | 08:36 PM
sleeperZ96BT's Avatar
Post
check your ground, if its not grounded well it will sometimes flicker or not come on at all (my problem).
brian
Old Jul 28, 2002 | 08:57 PM
megabass's Avatar
Post
Well, if you have power to the amp, it sounds like a signal or speaker wire problem. If it's a multi-channel amp, make sure the RCAs are going to the right set of inputs. Also check your speaker wire leads to the terminal on the box and then from the terminal to the sub itself. Other than that, it's hard to tell without more info. Good luck.
Old Jul 29, 2002 | 07:18 AM
CrAkD X 95TA's Avatar
Post
what kind of head unit do u have? some headunits require you to activate the preouts.
Old Jul 29, 2002 | 12:39 PM
tygreman's Avatar
Post
Are you installing subs to the amp or the factory. If its factory you have to bypass the amp by the spare tire.
Black 00' SS
(1) Pioneer 480
(3) 12" Solobaric L7s
(3) Earthquake 200Ds
(3) Marine Batteries
(1) 6 Farad Cap Bank
(2) 15" Compression Drivers (Loud AZZ Highs)
(1) Broken Trunk Latch courtesy of the L7s
C.A.N.I.
Conastant And NeverEnding Improvement
Nov 18, 2023 07:21 PM
Cam's maro
Mar 24, 2015 08:09 PM
NewsBot
Jan 8, 2015 11:29 PM
Chrisdude
Jul 24, 2002 02:25 PM
redz_02
Jul 24, 2002 09:42 AM
