Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
LT1 Fuel Line Questions?
Old Apr 28, 2009 | 10:27 AM
LT1CST's Avatar
Putting an LT1 Back into my car. When I removed my old LT1 (thinking I was going to go witha big block drag race setup) I Cut the lines directly behind the metal fittings that lead into the fuel rails. IS there a way for me to re connect those lines when my new motor comes by way of adapters of some sort? I would really pray that I dont have to replace the lines. Theres gotta be a way.
Chris
Old Apr 28, 2009 | 10:33 AM
mzgp5x's Avatar
I gutted all the gm stuff except for the fuel tank return line. All 1/2" alum, 3/8" socketless hose, and, some 1/2" steel brade hose. Modded the fuel rails for -an fittings. The stock stuff is not made for Perf modding (in my opinion). Oh yes... my app. --> 97ss 383ci D1 MM6 Moser 12 w/ twin 255 Walbro intank.
Old Apr 28, 2009 | 12:25 PM
LT1CST's Avatar
I think I might try and use some compressor fittings. With female openings on both ends. And try and mate it that way. Might be better than finding a hose with c-clamps
Chris
Old Apr 29, 2009 | 10:33 PM
Not clear what you cut... did you cut the metal hard lines, past the quick connects, or did you cut the plastic lines before the quick connects? What part of the plastic fuel line bundle is still there, if any?
Old Apr 30, 2009 | 10:34 AM
LT1CST's Avatar
Fred,
I cut them right behind the metal part.
Chris
Old Apr 30, 2009 | 10:24 PM
Still not clear whether you cut the METAL lines or the PLASTIC lines.
Old Apr 30, 2009 | 10:35 PM
LT1CST's Avatar
Fred,
I cut the plastic just before the metal
Chris
Old May 1, 2009 | 05:20 AM
Then just buy a new fuel line bundle. I would not try and repair the plastic lines. Or cut the connectors off the hard lines, get some 3/8" and 5/16" compression fittings, and run -6AN braided SS lines from the hard lines under the rocker panel to the hard lines at the rails.
Old May 1, 2009 | 03:24 PM
LT1CST's Avatar
Ok ill give it a shot thanks Fred
Chris
Feffman
Oct 9, 2015 05:42 AM
cmdeshon
Dec 27, 2014 10:06 AM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
