new setup.. new race car.
Old Apr 20, 2009 | 10:19 PM
qwik48r's Avatar
I'm on the fence about a set of new heads...
was going to run richards (west coast cylinder heads) stage 2 L92's.. but since they cant be milled any lower than 61cc's, my -10cc piston will only yield around 11.7 SCR... not going to work with the mid 260's duration hydraulic I am looking to run.
sooooo, he has pretty much talked me into running a set of edelbrock 245's... which flow pretty good for a classic cathedral port head (330's @ .650's)
they also have thicker deck than the stock L92 castings.... which will be more forgiving with a big hit... but its a 20cfm hit from the L92 castings.. which when your shooting for 650fwhp, counts.. milled to around 58cc's, it will yield around a 12.3 scr...
so my question has two parts: will the 245cc edelbrock be enough head to get me my goal? or would a compromise in compression for flow be better?
either way, the car will be carb'd... the cam in question will be a 263/263 .663/.663 on a 110.... on LSK lobes of course and rpm will be limited to 7300rpms.
thanks.
Old Apr 21, 2009 | 07:29 AM
Kraest's Avatar
Retired
What motor are you going with? Rectangle port heads won't work on an LS1. You need something with at least a 4.00" bore.
You can go with a much milder setup (cam wise) for that build. I've never used edelbrock heads before on builds, so I don't have an opinion on those.
That SCR doesn't sound right to me. A stock piston with a thinner headgasket and 61cc heads should yield around 11.3:1 or so. A stroker motor would yield much more compression and changed pistons would yield even more.
As a comparison, my 408 with 58cc heads and an aftermarket gasket with flat-tops yielded nearly 13:1 compression. I think you're possibly calculating it incorrectly.
Old Apr 21, 2009 | 02:22 PM
qwik48r's Avatar
let me clarify.
its a 408cui lq9 stroker with -10cc diamonds.
as it stands right now with a stock chamber 862 head, my scr is right around 11.7. I forgot the actual cc of the truck heads, but I believe its right around 61.5cc's.
I need to get my compression up into the high 12's to 13's to make this cam effective.
Old Apr 21, 2009 | 04:05 PM
Kraest's Avatar
Retired
Your pistons are killing you. There's no reason to ever go with a dished piston on an LS1 setup unless you're running boost.
As it stands (rough estimate):
4.03 bore
4.00 stroke
.045" head gasket
0 deck height
10cc pistons
61cc chamber
Around 11.4:1.
If you changed to a 58cc head, it would only be around 11.8:1
If you went with a 61cc and a 4.5cc flat top w/valve reliefs - 12.16:1
If you went with 58cc and a 4.5cc flat top w/valve reliefs - 12.62:1 -- That's what my old 408 in my sig was with LS6 heads and made 530/505 rwhp/rwtq.
There's tons of ways to make power ... running a 260 duration @ .050" isn't a necessity.
Old Apr 21, 2009 | 10:09 PM
Chrome383Z's Avatar
You are doing it backwards. Get the best heads/intake you can afford then talk to your cam/valvetrain designer for the best cam.
You don't select heads based on a cam, you select a cam based on the abilities of your heads/intake and goals.
Is this a drag race application?!
Last edited by Kraest; Apr 22, 2009 at 07:24 AM. Reason: BB was banned for scamming members here.
Old Apr 21, 2009 | 10:27 PM
mdacton's Avatar
I've heard those edelbrockjs are badass but never seen them on a car yet....
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Z28amustangklr
Middle Atlantic
Mar 28, 2015 03:08 PM
Joes96z
Dec 14, 2014 04:03 PM
