Shortening A4 shift tube
Old Apr 6, 2009 | 11:07 PM
fastcamz28's Avatar
I plan to shorten the shifter tube as I have a shifter **** adaptor and Hurst pistol grip shifter. My questions:
1. How much can I shorten the shift tube and white shift rod inside the tube?
2. What should I use to cut the tube and shift rod?
Thanks!
Mike
Old Apr 8, 2009 | 11:37 PM
The Captain's Avatar
I can answer #2. A reinforced cutoff wheel on a dremel. I am pretty sure you can take it down as much as half; you just have to make sure there is enough room for the handle if you plan on shifting all the way down to 1st gear.
This is one of my next mods, just got to find the time to do it.
http://www.ls1tech.com/forums/appear...installed.html
http://www.ls1tech.com/forums/appear...-write-up.html
Old Apr 9, 2009 | 06:19 AM
fastcamz28's Avatar
I really appreciate the response, especially the links. I plan to do the mod this weekend so this info is very timely. I was thinking of using a small tubing cutter I have and then using a dremel to cut the slots; may use it anyway to start the cut lines. Sure wish I could remove the metal tube; would make this mod very easy!
Received my pistol grip shift handle w/ the activator button in the mail yesterday. Adaptor should be here today. Already have a boot installed. Will post pics when done.
Thanks again!
Mike
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
Apr 16, 2015 09:57 AM
