will 94 z28 speed cluster work in 93 z28
Just what it says guys need help to find out if the cluster from a 94 z28 will work in a 93 z28. I hate the 93 cluster and have a 94 cluster but don't want to wast any time to put it in if it don't work. Thanks
Please read the post "stickied" at the top of the "LT1 Based Engine" forum, regarding bumping posts to the top. Wait at least 24-hours before doing so.
Have you "searched"? I know this topic was covered in the past 2 months, because I remember posting the differences between the tach driver on the 93 (from the coil, via a filter) and the 94 (from the PCM).
OK so whatever.... and we have posted a guideline that asks that you NOT push your posts to the top more than once every 24-hours.
If you have a problem with the actions of a moderator, take it up in a PM. Arguing in threads is not really welcome either.
For what it's worth, my '93 had a '94 cluster in it when I got it. Everything except the tachometer worked. The tachometer needle just bounced between 0 and 1000 RPMS sporadically. Injuneer has cited the reason for the lack of tachometer function in post #4. You'll definitely find more information on the issue if you do a search.
In the end, I did the exact opposite of what you're proposing. The white gauge cluster looked very out of place with every other yellow-ish indicator in the car, so I replaced it with the '93 specific yellow one.
Jul 4, 2005 05:00 PM
