Stall Wall Fix
Old Mar 31, 2009 | 10:47 PM
Matts1994Z28's Avatar
Stall Wall Fix
Can anyone tell me if this is correct? I have done alot of research and talk to a few people so I am hoping some other can shed some light. I don't see why this has to be sooooo secretive! here is a screen shot of the changes made.
Old Apr 1, 2009 | 09:52 AM
WS6T3RROR's Avatar
Just move the vss diagnostic all the way up, basicly disable it. The 1->2 shift thing is debatable and not always required I wouldnt do it unless it still showed up after a hard launch with the vss diagnostic turned up.
Usually with a stall you need to command the kickdown rpm and kickdown mph to be a little early to keep from banging the limiter (these are your wot shift table rpm and mph its just called kickdown for god know what reason).
No idea why this is such a closely gaurded secret, people are open about everything else but this they get hush hush on .
Old Apr 4, 2009 | 10:05 AM
MichiganSkip's Avatar
You guys that think this is a secret and can't find a fix, aren't trying very hard
https://www.camaroz28.com/forums/sho...ght=stall+wall
Search function is your friend
See post #2
lildemars09
May 28, 2015 07:54 PM
beltrunner
May 17, 2015 10:18 PM
edxiel
Jan 24, 2015 07:40 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
MislMan
Jul 19, 2002 11:41 AM
