Car won't start intermittently - possible causes?
Old Mar 29, 2009 | 07:01 PM
jrummi's Avatar
I have a 2002 SS. 75k miles, battery and cable were changed a couple years ago, maybe have 25k on them.
Sometimes when I try to start the car I turn the key and nothing happens, no clicks or slow starter or anything.(maybe 1 click but thats it). The volt meter reads about 11 (slightly in the red) before I turn the key fully.
Then I'll try again after a bit and it starts up fine, no slow turn over or anything. It may go a few days starting up fine every time, then have another episode.
What could the problem possibly be??
I feel like its not getting the signal to try and start but I don't know what that means. We have that little electrode thing in our key, could it be that something with that is bad and so the ignition won't recognize the key but then it finally does.
Once I tried to start it, turned the key fully,, and nothing but I just held it there and after about 1.5 seconds then it started up fast and normal.
Thanks for the help!!!
Old Mar 29, 2009 | 08:27 PM
Chevyssoccer's Avatar
yeah thats a pretty common problem. its the connection between the key and key cylendar. Try a spare key if you have one, clean the contact on the key, or bypass it. the key pellet is just a resistor... match the resitance on the two wires in the thin orange sleave going down the column
Britbilly
Jan 7, 2015 08:49 PM
Injuneer
Dec 15, 2014 09:36 AM
Dec 4, 2014 11:56 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
