what all gaskets do i need for my vented opti swap?
Old Jan 10, 2003 | 10:29 PM
weaponZ's Avatar
what all gaskets do i need for my vented opti swap?dal forgot to send them(he had alot going on)if i get the time for this tommorow i might try to knock this out.i need part number too.should i go to a local dealer or a parts store?if i dont do it tommorow i will order them from dal on monday.just trying to be prapared.thanks
Old Jan 10, 2003 | 11:37 PM
1loudz's Avatar
all you need is a timing cover kit. you can run down to auto-zone and pick it up. i believe its 12.99 as a matter of fact! i bought 2 in the past week. lol
-Ryan
Old Jan 11, 2003 | 08:50 AM
weaponZ's Avatar
forgot about that.i've bought a few of them thanks man
Old Jan 11, 2003 | 08:38 PM
weaponZ's Avatar
-Ryan
autozones here are out,will call somemore in the mourning.what all tools will i need.gear puller,prybar....?my mech. friend is out of town,so me and another friend are going to try to knock it out.thanks for the help
Old Jan 11, 2003 | 10:34 PM
97Camaro007's Avatar
All that I can think right now is just the waterpump gaskets......they are like 80 cents apiece. Do you have to take the timing chain cover off? If so then you will have to get the timing chain cover too.....hopefully you don't because you can get to the dal-pen though the opening in the timing cover.
Old Jan 11, 2003 | 10:39 PM
drop top steve's Avatar
You need a different timing case, a different cam or machine work on exsisting cam.
Old Jan 11, 2003 | 10:47 PM
weaponZ's Avatar
i got the new timing chain cover,so if all else fails i will just get the waterpump gaskets and timing chain cover gaskets,but machining down the dal pin or the cam is what im not sure about
Old Jan 11, 2003 | 10:48 PM
Venom93's Avatar
Yeah, you need the timing cover set from a parts store, that should come with the water pump gaskets so you don't have to worry about that. You do also need that new timing cover for the larger opti opening. Also, be prepared to take the cam out completely. If you can't get the old cam pin out that's what you may have to do. I had to take my cam all the way out and take it to a machine shop to get the old one out and the longer one pressed in there. Also, to save you some time looking if you don't know already, the new height for the pin should be .620". It may not be a one-day job, so make sure you have enough time.
Old Jan 11, 2003 | 11:19 PM
weaponZ's Avatar
thanks for the help
Old Jan 12, 2003 | 06:00 AM
Mtrhds94Z's Avatar
Nose of the cam has to be drilled also.. good time for a new one...
Old Jan 12, 2003 | 10:55 AM
weaponZ's Avatar
what are my options on a different cam?if that would make things alot easier
Old Jan 12, 2003 | 02:00 PM
Mtrhds94Z's Avatar
I got a Hot Cam on here for 100 shipped used.. that would be a good one I think...
And yes since it has to be pulled anyway why not change it?
Old Jan 12, 2003 | 03:26 PM
weaponZ's Avatar
i will consider that.can i just start with the hotcam and get the rest of the stuff down the road?i think i read where i couldnt
Old Jan 12, 2003 | 04:07 PM
Mtrhds94Z's Avatar
I would think as long as you don't do the 1.6 RR's, you wouldn't HAVE to do springs right now..
Old Jan 12, 2003 | 08:14 PM
weaponZ's Avatar
so it wouldnt be no problem.im trying to get the money up for a hotcam kit.kinda broke these days
