Nitrous plate problems
Old Mar 27, 2009 | 10:55 AM
ShownomercyZ28's Avatar
I am trying to install my Nitrous outlet plate for my LT1. I have a 58mm BBK and the IAC seems to be hitting the thermo housing and I can't get the holes to align with the plate in.
Any ideas?
Old Mar 27, 2009 | 03:32 PM
Ray@NitroDaves's Avatar
you need to clearance the thermostat housing and IAC....take material off in small increment while marking where it is hitting...give us a call if you need better instructions
Old Mar 27, 2009 | 03:34 PM
Yea, I called you earlier to confirm my suspicions.
Another random install question, I bought the kit used and it did not come with the extensions for the throttle cable plate. Can I get the from you separate?
Old Mar 27, 2009 | 03:37 PM
yes
ugggh...This forum requires that you wait 60 seconds between posts. Please try again in 35 seconds.
Old Mar 27, 2009 | 03:39 PM
LOL, any idea on how much they would run me?
Old Mar 27, 2009 | 04:50 PM
$25...will need to call order in
Old Mar 28, 2009 | 04:47 PM
Got the plate on today after some grinding and I hooked up the throttle figuring it would be way off but it was spot on.... Had some one look while I hit the gas pedal and blades opened WOT perfectly flat and closed like they should at idle.... weird?
Old Feb 17, 2012 | 08:30 AM
jqueen612's Avatar
Re: Nitrous plate problems
Jegs sells 1/8" water pump spacers that will move the pump and housing out enough to let the nitrous plate clear everything
camaroguy50613
May 27, 2016 09:00 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
alphaauto
Jan 23, 2015 07:42 AM
bandit383lt4
Dec 21, 2014 09:12 PM
