ls1 brakes on lt1 moser
Old Mar 21, 2009 | 06:44 PM
30th6's Avatar
im pulling my moser 9in out of my 97 and putting it in my 99 can i put the ls calipers on the lt brackets without any issues?
Old Mar 23, 2009 | 10:36 AM
mzgp5x's Avatar
I have a 12_bolt Moser in my 97ss. From discussions with Moser (I ordered new axle bearing due to oil leaks), they told me the purpose of the 1/8" shims between the outside bearing flange, and, the bearing. Moser designed the Moser 12 F_body axle for the 98 and up. The disc/ caliper on the 97 and lower years required the shim to run clearance spacing. No shim for 98 and later years. Moser was very helpful. B
Old Mar 23, 2009 | 11:55 AM
AL SS590 M6's Avatar
Moderator
As far as I know you'll have to pull the axles and remove all of the LT1 brake parts and the spacer. Then just install all the brake parts from your LS1 car and reinstall the axles.
Old Mar 23, 2009 | 07:24 PM
30th6's Avatar
thanks guys.
Brake_L8
Jan 20, 2015 09:44 AM
ddr698
Jan 9, 2015 10:05 AM
Jazsun
Dec 29, 2014 12:14 PM
vals95z
Mar 18, 2003 03:45 PM
