Getting hot after sts turbo
Old Mar 17, 2009 | 02:21 PM
vipercrt's Avatar
First of all, to merge all the discussions since the 2010 is coming out is kind of unorganized but that is just my 2 cents. Second, I have noticed since installing my sts turbo on my 1995 z28 October of 2007, within a min or 2 of idle, the engine is already close to operating temp. I have also noticed that it gets alot hotter than it used to (given it has always ran hot). Would a radiator flush help this or is this normal with boosted cars. What are some suggestions. Thanks.
Old Mar 17, 2009 | 02:29 PM
jsetzer's Avatar
Stock thermostat?
Turbo cars usually have a good amount of back pressure, and that makes the motor work harder. What are you calling operating temp? Reading from the gauge or from the computer with a scan tool?
For reference
I have an electric pump, 160 stat, stock rad, stock fans always on low, high at 175 if below highway speeds, and I run a pretty consistent 170-175 with normal driving - and see 190-200ish max when abusing the car.
Turbo motors will run warmer.
95blkss
Sep 22, 2015 03:18 PM
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 02:02 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
