Is aftermarket really better?
Old Mar 15, 2009 | 12:35 AM
SpeedZ28's Avatar
If I need to replace my gear (I'm staying with the factory 2.73), Is an aftermarket really going to be stronger then the factory's oem replacement? Like a Richmond for example.
Old Mar 15, 2009 | 12:55 AM
I believe the Motive gears are popular replacements because they were one of the GM OEM suppliers. Any genuine GM part is going to be a lot more expensive than a good quality aftermarket part, even with the available online GM parts discounts.
Old Mar 15, 2009 | 09:35 PM
SpeedZ28's Avatar
Well.....that doesn't really answer the question.
Your right GM replacement is more, but is it more because its better? I don't mind paying more if its because its better as far as quality and fitment.
Thanks for the reply.
Old Mar 15, 2009 | 11:04 PM
Spartan7's Avatar
From what I've heard, GM gears are more because they have tighter tolerances than other manufacturers, which is also why they are so quiet. But then I've heard others have absolutely no noise with properly set up Motive gears.
Old Mar 15, 2009 | 11:20 PM
If Motives are the same as the OEM gears, then aftermarket would not necessarily be better. But aftermarket would cost less.
Old Mar 16, 2009 | 03:20 PM
SpeedZ28's Avatar
I called the folks at http://agearworks.com/ they sell/install Motive and or OEM which is AAM and they said motive are a lot more noisy then the factory gears because the tolerances are not as tight and they recommended going with the oem.
Thank you.
Old Mar 16, 2009 | 08:47 PM
mrmint69's Avatar
Don't know why you would stay with the 2.73 but I bet there are 1000's out there that would give them to you for free because they all upgraded to the lower gears. If someone in you area has them that would save on S&H. Ebay has them all the time for $20-$30 and are used but in good condition.
Old Mar 18, 2009 | 12:16 AM
SpeedZ28's Avatar
I'm staying with 2.73's cause i like to be able to drive on the highway for an hour @ 100 or better without blowing my engine
Kinglouui
May 26, 2016 11:05 AM
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
CARiD
Sep 30, 2015 05:44 AM
SEOJustin
Sep 24, 2015 04:39 PM
Bxlt1
Sep 10, 2015 08:16 AM
