Is my FMIC causing overheating?
Old Mar 10, 2009 | 09:52 AM
miguelc's Avatar
Hello
Im running a camaro turbo, with a standing radiator. The car goes 180 F all day long withput intercooler, when I install the FMIC it goes to 220F.
There is 1,5 inches between radiator and FMIC, I tries with a paper with the fans running ant the car is sucking air by the intercooler( I cut space between foglights on my camaro 94).
should I move it forward ?, if anyone needs pictures I can get them when I get out of this office by night.
Thanks beforhand
Greetings form Gudalajara,Mexico, please help me build the firts LT1 turbo down here
Old Mar 13, 2009 | 12:58 AM
MikeGyver's Avatar
If you change nothing else other than the intercooler, then I'd say it's safe to assume that it is causing the overheating.
Should it be? probably not.
Lets see some pics.
How hot is the thermostat? in these cars the thermostat doesn't really control the coolant temp, the fans do.
Old Mar 13, 2009 | 08:27 AM
jsetzer's Avatar
I run a 160 thermostat - Intercooler is very close to my stock radiator which is vertical. Stock fans. I run 170-175 while crusing at low rpms. If I beat on it very much I I see 200ish pretty easily, but will cool back off after a little cruising.
Is this based on the gauge in the car, a scan tool? How are you reading it? Some gauges are not very accurate.
Old Mar 17, 2009 | 05:40 PM
boosted-lt1's Avatar
Still have the air dam on it?
-Scott.
Old Mar 17, 2009 | 08:22 PM
reamo04's Avatar
somebody over on TTF said maybe its nto having the black splash guards in the wheel well area? Is this possible? i guess
Old Mar 18, 2009 | 02:06 AM
MikeGyver's Avatar
I believe the stock tuning will turn the fans off above a certain speed. The idea is that the fans will actually impede airflow above a certain mph. This is probably not so in your case. You may need to make adjustments there.
Old Mar 18, 2009 | 03:47 AM
1982z28with18s's Avatar
How much timing you running at part throttle and wot? Timing does affect it, although the intercooler obviously is causing it to heat up more.
Old Mar 18, 2009 | 09:29 AM
jsetzer's Avatar
I don't have my plastic guards in right now, and I have no air dam. Mine is fed strictly through the hole I cut in the front bumper and is sandwiched with the radiator/intercooler together.
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
greenzee28
Sep 25, 2015 04:29 PM
damnyankee36
Sep 9, 2015 07:06 PM
Pwilson59
Sep 3, 2015 08:47 PM
