Anyone Using Nitrous Works? (also ET question)
Old Jan 9, 2003 | 06:23 PM
Punisha69's Avatar
Is this a O.K. System? I can get a new one for pretty cheap here locally... for those who run this, are you happy with it?
And... for everyone else... has anyone ever hit 11's on street tires? I hit 12.88 on street tires N/A... do you think if i was to spray 125shot in second gear i would hit 11's?
thanks guys.
Old Jan 9, 2003 | 08:22 PM
dlx3200's Avatar
I have the nitrous works system. The only thing i don't care for are the jets,they are hard to get.It seems they are always on back order.I hope this helps.
Old Jan 9, 2003 | 08:43 PM
Punisha69's Avatar
thank you... and is it true that they start at 125 shot?
Old Jan 12, 2003 | 11:22 PM
sprayed97Z's Avatar
NITROUS WORKS
I've got the Nitrous Works kit.It works good,and dependable.My kit is over 3 years old,never a problem.My jets go from 75,125,150,and 175.Remember to get rid of those plat. plugs.I run an autolite 103 gapped at .045.
Old Jan 13, 2003 | 01:22 AM
a walker's Avatar
I have the kit also and have had no problems. I shoot a 175 shot, and have gone 11.63 @118. My best without spray is 12.90's, so you should be able to do it if you're already going 12.80's. I was only able to do it once before my rear end broke (for the 3rd time).
Old Jan 13, 2003 | 09:33 AM
RacinLT1's Avatar
I had the nitrous works wet plate,great beginner system IMO.
I went from 13.2's to 12.0's with a 125 shot.
My biggest complaint is the LACK of holes in the spray bars,i believe there are only 4 holes per side of the plate.
I swapped to NX and ran the same 125 shot,and went 3/10's faster.
alphaauto
Jan 23, 2015 07:42 AM
ChrisFrez
Jan 11, 2015 03:47 PM
ChrisFrez
Jan 4, 2015 08:43 AM
bandit383lt4
Dec 21, 2014 09:12 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
