LS1/LT1 engine swap.....help
Old Mar 2, 2009 | 02:44 PM
2fst4upal's Avatar
Question LS1/LT1 engine swap.....help
I'm putting a 1999 LS1 w/trans into a 1995 Z-28.If anybody has done a swap like this and can help me with information/parts for this type of swap i could really use the help.Thanks.
Old Mar 3, 2009 | 06:41 AM
AL SS590 M6's Avatar
Moderator
Search this section for simular posts, there are many.
Old Mar 3, 2009 | 11:55 AM
danhr's Avatar
buy a wrecked donor car... you won't be nickeled and dimed to death.
Old Mar 3, 2009 | 06:30 PM
2fst4upal's Avatar
I'm need to know if the motor mts are different,will the 93-97 harness work with the existing ls eng(i have the ls eng harness as well as the ecm),but i want the gauges to work properly.I had been told this will drop in on the existing k-member,yet in jegs they list different k-members for 93-97/98-02 f-bodys.It's stuff like this that i need to confirm.
Old Mar 9, 2009 | 08:10 AM
My Iroc Z28's Avatar
You need the LS harness modified to work with the LT1 gauges... and I would recommend using the LS K-member, Steering shaft, & Rack n pinion. It will make life easier but if you don't want to you can use you LT K-member and just use adapter plates to get the motor to bolt up correctly.
Old Mar 17, 2009 | 02:36 PM
Antz97ZNJ's Avatar
...try ls1tech theres alof of info on this.
willismoons
Feb 14, 2015 08:42 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
centric
Aug 15, 2002 09:04 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
