jack points
Old Feb 3, 2009 | 04:33 PM
trippin holyman's Avatar
jack points
i tried to search and couldn't find it, but where are good points to jack 4th gens up? k-member, lcas? is there any other part i am missing?
Old Feb 3, 2009 | 07:12 PM
There are plastic pads at the rear of the front fenders (just don't get on lower lip of the fender where it says "don't jack here" (or something like that) ).
Old Feb 3, 2009 | 07:14 PM
The ones with the black grooved pattern? I think I read about that but wasn't sure.
Old Feb 3, 2009 | 07:25 PM
Green96Z's Avatar
I don't jack there anymore, mine started to crack. I use the point where subframe connectors would sit (the part of the subframe with 2 holes in it).
Old Feb 3, 2009 | 08:00 PM
Oxygen454's Avatar
My black pads say not to jack there... there is a little notch that I jack at...
Old Feb 3, 2009 | 09:13 PM
moparman's Avatar
That means to not jack on the fender lip. The pads are the jack point.
Old Feb 3, 2009 | 10:07 PM
That's what I tried to tell 'em.
Old Feb 11, 2009 | 12:55 AM
Oxygen454's Avatar
My stock jack only fits on the lip... in the notch-out
Old Feb 11, 2009 | 05:11 AM
The original poster did not limit his question to the stock jack. With other types of jacks, and with specific chassis lift types, there are numerous places other then the notch in the rocker panel lip, to jack the car. If using anything that does not have a perfectly flat surface, it would be a good idea to place something flat under the plastic jacking block, so it doesn't crack.
Old Feb 11, 2009 | 07:23 PM
2006Viper's Avatar
on the edge after fender pads.
after fender pads but befor middle off car. put some wood so u dont damage the wide little area .
Old Feb 11, 2009 | 09:04 PM
6SpdLT1Z's Avatar
I jack the rear on the rear subframe and put jackstands under the axle and the front by the pads on the subframe where the subframe connectors would go.
93 RedBird
Nov 15, 2015 08:24 AM
68camaroboltz
Oct 5, 2015 01:46 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
alliance12364
Sep 17, 2015 08:43 AM
