need some help asap!
Old Jan 7, 2003 | 12:17 PM
Timberwolf's Avatar
how do you remove the clutch pedal or the pedal set from a 69 camaro? I can see where it hangs on an odd pivot, but I couldn't see any bolts or anything holding it in...
I am supposed to sell the set to a guy today at round 5:00pm Eastern along with the rest of the manual trans setup. I assumed it was be easy to remove...
Old Jan 7, 2003 | 04:07 PM
angel71rs's Avatar
It should have a clip at the end of the pivot pin for the pedals.
Old Jan 7, 2003 | 04:25 PM
Timberwolf's Avatar
can it come out as an assembly? I think we are going to swap my maual trans pedal set for his auto trans pedal
Old Jan 7, 2003 | 06:33 PM
Teetoe_Jones's Avatar
Pedal removal
On the column/pedal support brace is a clip that retain the clutch pedal rod. It is on the right side of the brace between the gas and brake pedal. The clutch pedal is on a shaft that goes through the brake pedal. the master cylinder may have to be loosened for the brake pedal to come out, since the brake pedal pushrod has a clevis that can't be removed under the dash. The pedals slide out from the pass side toward the drivers kick panel.
Tyler
Devinfoote87
Sep 4, 2015 05:52 PM
asilomar244
Jul 12, 2015 05:53 AM
james4154
Jun 15, 2015 12:16 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
