how do you jack up your car with that rock gaurd thing in the way?
Old Jan 6, 2003 | 05:52 PM
fiz's Avatar
fiz
I have a new jack and I'm trying to jack up the front for an oil change, but that plastic gaurd is in the way.. it's too dangerous to try from the side.. how do you get around that?
Old Jan 6, 2003 | 07:23 PM
CLEAN's Avatar
Subframes baby!
Old Jan 6, 2003 | 07:27 PM
Mindgame's Avatar
What exactly do you mean by "plastic guard". Are you talking about the pad at the side under the door or what? Cause that's the place you want to jack the car from.
-Mindgame
Old Jan 6, 2003 | 10:36 PM
2002Z28SSConv's Avatar
Either jack it up from the frame rail on the side or use ramps. Ramps are WAY better for an oil change. Easier and much safer too.
Old Jan 7, 2003 | 12:07 AM
GrdLockV6's Avatar
I'm guessing you're talking about the air damn thing on the front underneath of the car? If so, my jack fits fine under it. Guess my jack is smaller then. After realizing my ramps won't fit under my car without scraping the bumper, I now jack up each side of the front by putting the jack on the k-arms, place a ramp under the wheel, then do the other side. Then if needed I jack up the rear via the differential.
Old Jan 7, 2003 | 01:18 AM
Ramp rub fix...
Either use Rhino ramps (not as tall) or lay a 2X4 down in front of each front wheel. When you drive up onto the 2X4's you get more clearance to be able to get onto the ramps without scraping.
I actually use 4X4's with a 45 degree cut on one side. But it's easy for them to slide because of the hight. If using 4X4's I suggest laying 2 side by side at each tire. That way you tires won't try to slide off sideways.
Jacks scare me. Even with stands. If used correctly, ramps are much safer.
Old Jan 7, 2003 | 12:06 PM
94BlackBowtie's Avatar
High-End Technical discussion here!
Hehe...
Just messing with buddy...I usually go in from the front at an angle...missing the air dam plastic piece. I use like a 3 ton Race Jack and have no problems clearing/doing it this way - and that thing is pretty big. Just go in from the corner in front of either wheel, and jack it up from the center of the crossmember...that's how I do it anyway, between that and the jack stands, I would lay under it for hours.
ModdedNerd
Jan 1, 2015 10:56 AM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
Hal Fisher
Sep 14, 2002 09:36 PM
JasonD
Jul 15, 2002 02:17 PM
