oil moisture under throttlebody area
Old Dec 19, 2008 | 02:03 PM
1of365's Avatar
Can't figure it out, i have a small amount of oil on the bottom of the hood which i clean off each weekend when detailing the car. I just replaced the stock airbox with an SLP version and when i took of the assembly i noticed a good amount of oil on the bottem side of the air bellow connection where the air flows into the throttle body. anyone have ideas? I keep the engine bay clean so there is no other oil that i can see????
Old Dec 19, 2008 | 07:18 PM
johnny6's Avatar
Are you sure you don't have a leak around the rotating assembly and it's shooting up into the engine bay? Start the car, put it on ramps/jack stands and check around for leaks. There's an oil leak, you just have to find it. What about the oil level? Has it been dropping?
Old Dec 20, 2008 | 06:37 AM
AL SS590 M6's Avatar
Moderator
Maybe power steerng cap seal?
Old Mar 1, 2009 | 02:53 PM
1of365's Avatar
found it power steering return line. dealership replaced, not cheep for that much labor.
May 8, 2015 11:30 AM
blkWidow
Apr 20, 2015 09:27 AM
BigWil
Mar 29, 2015 12:24 PM
squarehead
Nov 21, 2014 08:02 PM
Mike Meyers
Jul 25, 2002 07:35 AM
