Please Help
Old Dec 12, 2008 | 05:26 PM
1996impalass's Avatar
Angry Please Help
I have a 2000 Camaro SS that I just replaced the stock front and rear sway bar bushings and endlinks with Energy Suspension stuff. I also added the transmission mount from Energy I have picked up a bad vibration. Is there a certain way you are suppose to tighten the endlinks and bushings on swaybar so it isn't too tight or loose as heck. I read some posts about the trans mount causing problems why would this be I wonder. Thanks in advance for your help
Old Dec 12, 2008 | 08:47 PM
It's more than likely the trans mount. They are known for tranferring vibrations on a lot (but not all) of cars.
Old Dec 12, 2008 | 09:20 PM
bluz28's Avatar
Lightbulb
Trans mount!
I went through the same thing over 5 yrs ago.
Cut/grind off the 2 pre-load bumps on the E.S. trans mount then remount it; problem solved!
Old Dec 13, 2008 | 12:15 AM
do you remount with the shim plate back as well thanks I will work on today
Old Dec 13, 2008 | 07:24 AM
RUDEDOG's Avatar
Lose the shim plate.
Old Dec 13, 2008 | 07:48 AM
johnny6's Avatar
I had the same problem a couple of years ago, i had the poly trans mount. I put up with the vibration for a while but then i changed it to a advance auto mount and no more vibration
Old Dec 13, 2008 | 03:45 PM
slomarao's Avatar
f poly bushings. I put them in my car when i was first turned on to them and now i am working to get rid of them in my car. Lost the trans mount.
