Wiper fluid wont come out!
Old Jan 5, 2003 | 04:23 AM
xpimpitox's Avatar
Angry Wiper fluid wont come out!
Hey guys when i pull the lever for the fluid 2 come out it wont work! can anybody help me out on this i dunno what it could be. probably sumthin simple but im learnin about cars thru my iroc so im gettin there. thanx all
Old Jan 5, 2003 | 08:18 AM
87DJP2001's Avatar
In most cases the pump dried out for lack of use. You will have to prime the pump if its still working.
Old Jan 5, 2003 | 08:29 AM
aklim's Avatar
Don't start the car but put it in run position and try the wiper fluid spray. If you don't hear a sound go to the wiper motor and hook up a light there where you can see it and try flipping the switch. If it lights up there is power at the pump. In that case, buy a new pump. If not you need to trace wires and what not.
Old Jan 5, 2003 | 09:29 PM
stanghunter211's Avatar
I went through the same thing. I even went through the trouble of swapping the motor, still did it. It works now, but unless you use it daily, even as I do, it still sticks. I always heard the motor, just nothing came out. I find that if I give the car gas, or stop quickly, the sudden change in motion sometimes forces the liquid through. Weird, but it never fails. I changed all the rubber hoses, lubed everything up, still does it. Sometimes I can sit there and hold that thing for a good 25-30 seconds before anything comes out. Its a pain, but not much you can do. Hope that helps//
Will
Old Jan 6, 2003 | 01:57 AM
xpimpitox's Avatar
Thanx all
Old Jan 6, 2003 | 03:12 AM
stonedchihuahua's Avatar
You probably have a leak... look where the wiper motor is first.. my car did this when I first bought it but I found the hose was laying on the wiper setup and over time got eaten away
blac94Z
Nov 4, 2015 01:59 PM
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
autoxr166
Sep 25, 2015 04:21 PM
