Abs
Old Dec 3, 2008 | 07:20 PM
4thgencamarofan's Avatar
Abs
Where is the ABS module on a 95 3800 auto???? I found out the hard way today my ABS doesn't work. (Stated slidin on ice so corrected the sterring and hit the brakes and the just locked up and i knicked a mailbox Woops)
Didn't damage anything but the pole on the mailbox and a little dent in my front bumper that was already scraped up when I got it.
Old Dec 7, 2008 | 10:50 AM
Guest47904's Avatar
Guest
What makes you think it wasn't working, just cause you were sliding? If it wasn't working the PCM would have diagnostic codes. Have you tried scanning it? Did the "low trac" light come on while you were braking?
Does the "low trac" light come on during the pre-start diagnostics?
The EBCM is located above the driver left foot. It's a silver metal box.
You could still have a brake issue like a sticking piston even though the ABS is functioning.
Old Dec 7, 2008 | 08:38 PM
Yes the low trac light does come on when the tires lock but it doesn't do anything to stop them from locking.Yes also comes on when you start the car. I'm going to get it scanned tomarrow. How could I tell if the piston it sticking?????
Old Dec 8, 2008 | 03:48 PM
Guest47904's Avatar
Guest
I think your system is fine. It may be your driving needs a little help. If the system were not functioning, the ABS OFF light would be on and the low trac light would not come on.
If your looking for a sticking brake, just jack up a wheel and rotate it. Hit the brakes and then let off and try to rotate the wheel again.
Just for laughs go to an area where there is loose gravel or sand and try braking with 2 wheels in the loose material to see what happens. Then pull the 5 amp fuse #1 UH and try the same thing in the loose material again.
Old Dec 8, 2008 | 06:24 PM
I have been testing them on the snow and ice...i'll go nice and slow 5-10 and just slam on them to see if they're working. Sometimes there's just a tiny bit of pulsating in them which would mean they're working but then other times theres absolutely nothing. But I don't think i'm gonna have to worry about cuz i think i got someone that will buy my car.
IndyZman
Oct 22, 2015 02:17 PM
TGGodfrey
Aug 17, 2015 08:43 PM
tnmotown
Aug 10, 2015 11:52 PM
realistyc
Jul 28, 2015 07:32 PM
