pwr acc no 7 fuse = battery draw
Old Nov 29, 2008 | 05:49 PM
Muncie4sp's Avatar
Figured out I had a bad battery draw killing my battery in less than 24 hours after each time turning it off. I narrowed the draw down to the PWR ACC fuse 7.
Has anyone come across this with a fix?
Only things on that circuit are the: park lamp relay, hatch release relay, power mirror switch, radio, shock sensor, instrument cluster.
Any help would be great
Old Nov 30, 2008 | 01:26 AM
Muncie4sp's Avatar
problem found
I was able to narrow the draw down to the pwr acc fuse.
I disconnected the positive cable from the battery and jumped a test light between the positive terminal on the battery and the positive cable. Immediately the test light lit up, bright. I removed the pwr acc fuse and it dimmed then when I removed the radio fuse it dimmed a lot more. With the two fuses removed it was only drawing .18 amps, not enough for a dead battery. Before it was a 3+amp draw.
So it was narrowed it down to the radio. The factory radio has a short in it. I wont know 100% sure until I replace it with another
I will update the post with results.
Old Feb 23, 2009 | 07:18 PM
KAO 91's Avatar
Did you ever solve your problem? I have a 2.3 amp draw on the same fuse. Replacing the head unit made no difference for me. Thanks for any info you can provide!
Old Mar 4, 2009 | 06:43 PM
camaronutt's Avatar
I just put a new battery in my car and went out in the morning to a dead battery. I may have the same problem. I'll have to check this out further. Kind of a PITA!! Luckily I can bump start it in the driveway.....
Old Mar 5, 2009 | 01:54 PM
KAO 91's Avatar
Is your problem related to the same fuse?
Old Mar 9, 2009 | 07:39 PM
camaronutt's Avatar
I don't think. It seems to be fine now. Not sure what was going on. It sat for a few days and started right up tonite.
Old Mar 10, 2009 | 10:28 PM
BcableLEX's Avatar
Same Issue..
I have a 2000 Camaro B4C.. Mine pulls .49 amps when the power accy fuse is in.. Nothing when the fuse is out..
Jeff1904
Jun 5, 2016 05:00 PM
68camaroboltz
Oct 5, 2015 01:46 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
jackpawt883
Sep 10, 2015 08:53 PM
