View Poll Results: Does anybody have a clue to the leak???
Windsheild
0%
anything else
100.00%
Voters: 1. You may not vote on this poll
Water in floor board!! Not HeaterCore!!
Old Jan 4, 2003 | 12:05 AM
DarinsTA's Avatar
Unhappy Water in floor board!! Not HeaterCore!!
Hey has any body ever had a problem with their car getting water in the floor wnen it's raining???? Mine started a few weeks back. It's not the heater core( no antifreeze in the floor) I also checked the weep hole in the A/C box it's clean( I even ran a rod up in it to make sure) .. I think it may be coming around the window.. seems funny to just all of asudden start leaking.. Any help or info would help and be appreciated.
Old Jan 4, 2003 | 01:16 AM
Donny O's Avatar
that happened on my del sol....replaced windshield(it was cracked on the other side anyway) and it never leaked again
Old May 26, 2003 | 08:18 PM
Z28x's Avatar
Is you leak in the back seat or front, I just noticed mine leaks in the back passanger side when I drive in the rain, but only while driving. It's not leaking from the T-tops or side window, it seams to be coming up from the floor.
Old May 26, 2003 | 09:40 PM
zuluman13's Avatar
Mine is in the front driver floor under the pedals it mainly happens when I wash it or a really heavy rain
Old May 26, 2003 | 09:47 PM
1BadBird's Avatar
It's probably coming from you're hatch.Only REAL way to tell is take off your sail panel on the driverside and spray the hatch for awhile then check inside the car. It's probably seeping in where the curve is in the weatherstripping and running down the body curves inside the car and settling in the rear paasenger seat well.Then getting overflowed onto the floorboards. Slightly easier way to check is to take out the rear seat on that side(only held in by 1 bolt I think) and look for pooling water. I had it happen and sealed EVERYTHING I could think off then decided to rip the entire interior out of the car and dry it that is how I found mine.
Old May 26, 2003 | 10:03 PM
95BLKTA's Avatar
mine does the same thing,. its the seal on the leading edge of the passenger window where it meets the plastic triagle that the side mirrors bolts to, just get a new window seal.
shouldnt cost much, cheaper that replacing the floorpan in a few years!
Chris
Old May 27, 2003 | 06:13 PM
Donny O's Avatar
wow bringing it back from the archives!!!!
Camarokid95
Jun 12, 2015 11:25 PM
Jun 5, 2015 10:16 AM
supercharged94Z28
Jun 2, 2015 03:32 PM
May 8, 2015 11:30 AM
Mar 13, 2015 07:15 AM
