Those of you running oil scavenge pump or alky kits...
Old Nov 17, 2008 | 12:24 PM
RealQuick's Avatar
... which wire are you guys tapping into to get power for those pumps? I assume an ignition wire, but which fuse it in the relay box?
Old Nov 17, 2008 | 03:53 PM
subarubill96's Avatar
any orange wire should give it to you IIRC they are 12V switched but might be just 12V hot. i think my old LL setup was tapped that way so you could check that out if you wanted. you running them off a relay ?
Old Nov 17, 2008 | 03:55 PM
RealQuick's Avatar
I'll check it out. Thanks Bill.
Old Nov 17, 2008 | 04:06 PM
how you wiring the pumps? relay or just hot 24 /7 switched?
Old Nov 17, 2008 | 06:22 PM
RealQuick's Avatar
Not sure which is the best way. i guess a relay is best huh?
Old Nov 17, 2008 | 08:11 PM
for the oil scavenge pump i would use 12 V switched to have it running when the engine is going just for ease of install (no switch to forget to turn on, etc) as far as your alky kit, its up to you, im not sure what the amp draw is on it but i imagine its significant so a relay would make that a little easier on the electrical setup. if you need a hand, id be glad to help you wire it up
Old Nov 17, 2008 | 08:29 PM
RealQuick's Avatar
I found a relay that came in the alky kit, so now it's down to the oil pump. If i run the pump off the standard 10A fuse in the fuse block, and the pmp draws 10A, should I switch out the 10a fuse to 20A (to accomodate for the original 10A + the pump which draws 10A)?
Old Nov 17, 2008 | 08:33 PM
jon, give me a call i think i could answer all your questions in one quick shot
Old Nov 17, 2008 | 08:39 PM
RealQuick's Avatar
I'll give ya a call on the way to the shop tomorrow night (around 5pm). i got 0 bars on my cell right now.
Old Nov 17, 2008 | 08:41 PM
sounds good. hopefully i can explain it on the phone better than i can write it lol just keep that relay handy and we will be okay.
Old Nov 18, 2008 | 08:45 AM
RealQuick's Avatar
Pretty sure this is the right way to run the oil pump:
the ignition wire from fuse box ---> relay ----> ground. Then across the relay is 12V hot (all the time) --->relay --- > fuse for the pump ---> pump ----> ground?
HectorM52
Jul 30, 2017 11:46 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
Scottylt1
Jan 8, 2015 02:48 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Queens94z28
Dec 20, 2014 09:11 PM
