ls3 ss 430hp!!!
Old Nov 13, 2008 | 10:31 AM
GSS9909's Avatar
ls3 ss 430hp!!!
I just had and update last night on autobook and this is what changed in the power tain tab
Prepared By:
administrator
2010 Retail Chevrolet Camaro 2dr Cpe 2SS 1ET37
TECHNICAL SPECIFICATIONS
POWERTRAIN - BASIC SPECIFICATIONS - 2010 Retail 1ET37 2dr Cpe 2SS
ENGINE
Engine Order Code LS3
Engine Type HO Gas V8
Displacement 6.2L/378 CID
SAE Net Horsepower @ RPM 430@ 5900
SAE Net Torque (lb ft) @ RPM 424 @ 4600
TRANSMISSION
Transmission order code MN6
Transmission Type Description 6-Speed Manual
Drive Train Rear wheel drive
MILEAGE
City EPA fuel economy estimate (MPG) - TBD -
Hwy EPA fuel economy estimate (MPG) - TBD -
City cruising range (mi) - TBD -
Hwy cruising range (mi) - TBD -
* Indicates equipment which is in addition to or replaces base model's standard equipment.
Report content is based on current data version referenced. Any performance-related calculations are offered solely as
guidelines. Actual unit performance will depend on your operating conditions.
GM AutoBook, Data Version: 144.1, Data updated 11/11/2008 11:29:00 AM
©Copyright 1986-2005 Chrome Systems Corporation. All rights reserved.
Customer File:
November 13, 2008 9:26:31 AM Page 1 Prepared By:
administrator
POWERTRAIN - ADVANCED SPECIFICATIONS - 2010 Retail 1ET37 2dr Cpe 2SS
TRANSMISSION
Gear Ratio (:1)
First Gear Ratio (:1) 3.01
Second Gear Ratio (:1) 2.07
Third Gear Ratio (:1) 1.43
Fourth Gear Rato (:1) 1.00
Fifth Gear Ratio (:1) 0.84
Sixth Gear Ratio (:1) 0.57
Reverse Ratio (:1) 3.28
Clutch size (in) - TBD -
Final Drive Axle Ratio (:1) 3.45
ELECTRICAL
Battery 1
Battery cold cranking Amps @ 0 F - TBD -
Alternator
Alternator Amps 150.00
COOLING SYSTEM
Cooling system capacity - TBD -
Customer File:
November 13, 2008 9:26:31 AM Page 2 Prepared By:
administrator
PAYLOAD/TRAILERING SPECIFICATIONS - 2010 Retail 1ET37 2dr Cpe 2SS
WEIGHT INFORMATION
Base curb weight (lbs) 3,860.00
TRAILERING Max Trailer Wt. Max Tongue Load
Dead Weight Hitch (lbs)
Weight Distributing Hitch (lbs)
Fifth Wheel Hitch (lbs)
Customer File:
November 13, 2008 9:26:31 AM Page 3 Prepared By:
administrator
CHASSIS SPECIFICATIONS - 2010 Retail 1ET37 2dr Cpe 2SS
SUSPENSION Front Rear
Suspension Type Multi-Link Strut 4.5-Link Independen
Suspension Type (cont.) Double Ball Joint
Shock Absorber Diameter (mm) - TBD - - TBD -
Stabilizer Bar Diameter (in) - TBD - - TBD -
BRAKES
Brake type Pwr
ABS System 4-wheel
Front Rear
Disc Yes Yes
Rotor Diam x Thickness (in) 14 x 1.26 14.4 x 1.1
Drum
Drum Diam x Width (in)
TIRES Front Rear Spare
Tire Order Code QOO QOO
Tire Size P245/45R20 P275/40R20
WHEELS Front Rear Spare
Wheel Size 20 x 8 20 x 9
Wheel Type Aluminum Aluminum
STEERING
Steering type Pwr
Ratio (:1)
Overall 16.10
Lock-to-Lock Turns 2.50
Turning Diameter
Curb-to-Curb 37.70
Wall-to-Wall - TBD -
Customer File:
November 13, 2008 9:26:31 AM Page 4 Prepared By:
administrator
FUEL TANK Main
Capacity 19.00
Customer File:
November 13, 2008 9:26:31 AM Page 5 Prepared By:
administrator
DIMENSIONS - 2010 Retail 1ET37 2dr Cpe 2SS
EXTERIOR DIMENSIONS
Wheelbase (in) 112.30
Length, Overall (in) 190.40
Width, Max w/o mirrors (in) 75.50
Height, Overall (in) 54.20
Tread Width
Tread Width, Front 63.7
Tread Width, Rear 63.7
Min Ground Clearance (in) - TBD -
CARGO AREA DIMENSIONS
Liftover Height (in) - TBD -
Trunk Volume 11.3
INTERIOR DIMENSIONS
Passenger Capacity 4
Passenger Volume (ftł) - TBD -
EPA Classification Compact
Seating Position Front Second
Head Room (in) 37.40 35.30
Leg Room (in) 42.40 29.90
Shoulder Room (in) 56.90 42.50
Hip Room (in) - TBD - - TBD -
Customer File:
November 13, 2008 9:26:31 AM Page 6"
Old Nov 13, 2008 | 10:45 AM
JakeRobb's Avatar
Super Moderator
Cool, lots of good info in there. I wonder if it really will be 430hp...
Old Nov 13, 2008 | 11:42 AM
2001SS4Doc's Avatar
http://www.gmperformanceparts.com/se...o_sitelet.html
The Dale Jr. version at SEMA has 430hp and 444 ft-lb.... I like
"L-92 type" rectangular port heads heads, int/exh: 0.551/0.522 lift, 204/211 dur, 2.165"/1.59" for a wide flat touque curve...anyone wanna take a stab at the LSA??
Old Nov 13, 2008 | 12:48 PM
99SilverSS's Avatar
I have no doubt that the LS3 is rated 430hp in either Vette or Camaro but what does the difference in intake and exhaust seen on the Camaro do to that power output. In any event 422hp is just fine with me. The LS3 and it's potential is the key.
Old Nov 13, 2008 | 01:11 PM
SSPORT10's Avatar
Very interesting...wonder if that is really true and will the L99 be rated higher than 400 hp when it finally is SAE certified.
Old Nov 13, 2008 | 01:17 PM
Gripenfelter's Avatar
I'm gonna guess 412 for the auto. Or 422.
Old Nov 13, 2008 | 05:38 PM
SSPORT10's Avatar
That sounds allright to me! Would be glad to see a hp bump when my Camaro with auto comes in Feb/March.
Old Nov 13, 2008 | 05:44 PM
ImportedRoomate's Avatar
Nice. Even though it really doesn't matter that much, that puts it up over the SRT8.
Old Nov 14, 2008 | 07:42 AM
JakeRobb's Avatar
Super Moderator
Old Nov 25, 2008 | 11:57 PM
Big Als Z's Avatar
19 gallon tank?!?! Sheeesh! Getting like 25mpg, thats 475 miles to the tank!!
If could squeek out 30mpg, thats nearly 600 miles to a tank!!
430hp, thats cool too.
Old Nov 26, 2008 | 09:55 AM
CTK1's Avatar
I'm willing to bet that the LS3 is 430 horse power. It is the same engine that is in the C6, and I doubt GM would honestly spend the extra money to detune it. They probably just rate it lower so Corvette owners don't get upset. Just my Opinion though.
Old Nov 26, 2008 | 10:00 AM
JakeRobb's Avatar
Super Moderator
It's not about spending extra money. The intake and exhaust are different, and so it won't necessarily have the same amount of power.
Here's hoping it does.
Old Nov 26, 2008 | 11:49 AM
Big Als Z's Avatar
Funny that the G8 GXP is 415, while the Camaro gets a supposed 15hp bump?
Old Nov 26, 2008 | 05:46 PM
Geoff Chadwick's Avatar
The C6, G8, and Camaro all have true dual exhaust with an X pipe, and from the pics I've seen all appear to be a similar diameter pipe with similar number and quality of bends.
Power under the 430hp mark is due to either (a) its 430hp and they just mark it less to keep vettes happy (b) due to really bad mufflers and/or cats (c) exhaust manifolds that are terrible or (d) a de-tune.
Awesome looking G8 underside shot for reference
Old Nov 26, 2008 | 05:59 PM
They shouldn't be able to fudge the numbers. All they can do is design components like the intake and exhaust to get the numbers they want.
