port and Polish
Old Jan 3, 2003 | 04:19 PM
Green G0blin's Avatar
port and Polish
what is necessary when you port and polish some heads?
do i need to upgade my internals? and if so..what are considered internals...
like give me a list of everything i need to upgrade...thanks.
Old Jan 3, 2003 | 04:33 PM
or...anyone have a site where i can refer to..to actually read up on what port and polishing really is? as far as the details and stuff.
Old Jan 5, 2003 | 12:59 PM
kahouna23's Avatar
port and polishing your heads is simply removing your heads, laying a gasket on it, tracing it with a scribe or something that will leave a mark. Then, patiently sitting in a chair with safety glasses, and a couple cases of beer with a dremel tool or die grinder......slowly boring out the ports to the lines where you traced. You'll notice the difference.....
Old Jan 6, 2003 | 01:51 PM
DEE97GTP's Avatar
Woah, wait a minute. It is alot more than that if you expect to see good gains. What you are talking about is gasket matching, etc. The real gains are in the ports, bowl area, and around the valve.
DEE
Old Jan 6, 2003 | 03:38 PM
2turboz28's Avatar
he is right about there bieng alot more to it than just grinding away metal. i know this because it is part of my job. you could try reading back issues of magazines or buy a book from summit. even this is just a sample of the things that you need to know about porting. if you want it done professionaly then email me.
Old Jan 6, 2003 | 05:49 PM
kahouna23's Avatar
Thanks for setting me straight. I had mine professionally done so I was kinda in the dark. A few guys from work told me that I was stupid for having it done because all they did was grind away metal. Shows what they know, and me for that matter.......live and learn I guess.
Old Jan 7, 2003 | 07:52 PM
viper98885's Avatar
There is a lot of technical skill that goes into a GOOD P&P job. A set of heads that it ported wrong will flow horribly and somtimes hurt performance.
Old Jan 8, 2003 | 02:03 AM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
great place to start your quest for P&P'd heads and intake http://www.sa-motorsports.com/diyport.htm
Old Jan 8, 2003 | 10:57 AM
thanks ATL....i will go read :P
Old Jan 8, 2003 | 06:07 PM
Joshs99BlackBeauty's Avatar
About how much does it cost to have heads p&p professionaly? Where would you go to do that? What kind of gains in the 1/4 will you see?
Old Jan 8, 2003 | 08:18 PM
viper98885's Avatar
When I had mine done, they were $700 for the P&P job with the lower intake match ported and polished at the same time. At the time, I thought this was pretty expensive, but now that I researched it, that's about the going rate for a job where the person knows what they are doing. You can probably find some people that will do it cheaper, but the quality of the work will probably not be as good.
When they did my heads, they also recut the valve seats and polished the combustion chambers....if you want more info, click the link to my car below and it will detail the work done.
Old Jan 9, 2003 | 01:41 AM
atl2001's Avatar
yeah you can get them P&P'd for not too bad , around 500 ish , but the bowl work is where it gets expensive
G-BODYT56
Jan 14, 2022 11:14 PM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
