oil pan questions for my D1 383
Old Nov 4, 2008 | 07:29 PM
97sstroker's Avatar
I've got canton pan #15-242 and the pickup tube ive got is front sump mount, does the recommended pickup tube mount in the back of the pan? does anyone know?
Old Nov 7, 2008 | 12:39 AM
blown383's Avatar
It always mounts on in the back of the pan. Depending on the oil pump you chose you're going to need the correct pick up tube.
-B
Old Nov 8, 2008 | 09:22 AM
Boosted_Z28's Avatar
Call Canton with the part number of the oil pump you plan to run. More than likely, they will have a pick-up that will work with their pan. If not, they will advise you on which oil pump to use.
Old Nov 8, 2008 | 06:39 PM
blown383's Avatar
Here are some pictures of the Canton 242-T pan tapped for a D1 oil return.
You can see the oil pump pick up tube here.
Obviously not the best welding in the world but it gets the job done.
-B
Old Nov 9, 2008 | 06:33 AM
mzgp5x's Avatar
I have same set-up. Also, 383 with D1 and Canton road pan. Had the same problem with the pick-up (purchased the wrong one for a Melling high vol pump). Canton helped. I run my D1 oil return line (1/2 alum hard pipe) to a fitting on the passenger side near the starter. Have not had any problems. B
HectorM52
Jul 30, 2017 11:46 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
Elcojoe
Nov 17, 2014 10:27 PM
