342 gear rear end question
Old Jan 2, 2003 | 07:09 PM
IrocAngel77's Avatar
ok my car has been acting strange lately. it makes a wierd groaning noise when i turn the wheel slightly to the left and pull into a parking spot (not the usual cracking noise it makes when the wheel is maxed to the right) or sometimes when im going to stop at a light thats on a hill with the wheel streight. the groaning noise is pretty loud and i can feel it almost under my feet. i dont know what is causing this as it doesnt always happen. i was thinking could it be my 342 gear rear end needs to be oiled? or what happens when a rear needs oil. ive never had this problem with any of my other thirdgens. i dont think its my steering cause my fluids are perfect and it has no leaks there.
Old Jan 2, 2003 | 08:44 PM
mjcent922's Avatar
Try performing a rear end service first.Go down to your local GM dealer and pick up some diff lube w/ the Gm limited slip additive.To preform remove rearend cover to drain fluild.Clean cover and reinstall w/ new gasket.Torque bolts to 30lbs.-ft.Next remove the rearend fill plug(located at the back oft the rearend)and add 2 quarts gm of lubricant(#1052271) and then the limited-slip additive(#1052358).If that does'nt work it sounds like you might have a bad bearing in there.
Old Jan 3, 2003 | 12:59 PM
TheGreatJ's Avatar
Sounds to me like you just need a general chassis lube. Get a grease gun and crawl underneath and shoot some lithium grease into every grease fitting you can find. I don't know what is/is not greaseable with the stock equipment, but almost all aftermarket suspension pieces have grease fittings and need to be greased regularly.
oldschool
Feb 9, 2016 09:21 PM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ModdedNerd
Dec 25, 2014 05:51 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
