v6 Rearend vs LT1 Rearend?
Old Oct 27, 2008 | 08:42 AM
meissen's Avatar
Hey guys,
I know there's some sort of difference but what's the main difference between the LT1 and v6 rear ends? Just different gears? Could I take my v6 rear end and convert it to calipers, change the gears, and be good to go with an LT1? It's an automatic, if that makes a difference, but will be set up with a 2500+ stall.
Old Oct 27, 2008 | 09:39 AM
sn8ke eatr's Avatar
im pretty sure the only difference is the brakes and the posi
Old Nov 5, 2008 | 07:04 PM
Z28LT1_Just_Nasty's Avatar
I converted a v6 shell into essentially a Z28 clone from a Z28 donor car. The rears are identical. Moved the posi over from the Z28 and just swapped the ring gear. I'm in the process of moving over the brakes right now but ran the drums for couple months.
Some of my mods are in my sig, and this is all going through the v6 rear. You'll be fine.
Old Nov 6, 2008 | 11:06 AM
blue 79 Z/28's Avatar
yea, its basically gears, posi, and brakes. some Lt style v6 cars got 3.42's anyhow in the 3.8L ones. if its an Ls diff, they have a posi optional and all use the big discs.
ddr698
Jan 31, 2015 10:58 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
ddr698
Jan 9, 2015 10:05 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
